IS 4.75 BACKSPACING ENOUGH TO RUN 35s???
Old May 11, 2011 | 10:51 AM
daylon101's Avatar
Default IS 4.75 BACKSPACING ENOUGH TO RUN 35s???
Alright i've got some Pro Comp 17x9 wheels with 4.75 backspacing and -6mm offset. I run a 33 12.50 17 right now on the with no rubbing issues with no lift. I have an opportunity to pick up some 315 70 17 BFG A/T's really cheap. Will my wheels have enough backpace to run these tires along with the OME HD lift without rubbing?
Old May 11, 2011 | 10:55 AM
fadeout's Avatar
Yea that's the same size wheel I run. You'll be fine the only rubbing I intially had was on the plastic air damn.
Old May 11, 2011 | 10:59 AM
GentlemanFarmer's Avatar
If it can help, I run 315/70R17 Duratrac with 17x9 5.5" Backspacing (+12mm offset). No rubbing at all even at full flex. My lift is 2.5" Teraflex BB.
I think 5" backspacing would have been the limit, otherwise the tire would hit the fenders at full flex. With more lift it would be fine.
Old May 11, 2011 | 11:00 AM
Flaxbourton's Avatar
I run 4.75" with 37"s and no rubbing. My wheels are 17x9 Pro Comp 8179s.
