4" lift and 37's. Rubbing?
Old Oct 30, 2011 | 12:58 PM
bayoujk's Avatar
Default 4" lift and 37's. Rubbing?
IM considering going to 37's this week but I'm concerned that I will end up with a whole list of problems. I believe my procomp wheels have 4.5" backspacing I have a 4" zone suspension lift and cut factory flares...... Looks Like a lil sway bar rubbing could happen up front... Any input. My 35's don't rub at all.
Old Oct 30, 2011 | 02:21 PM
Southern Girl's Avatar
^^^x2 on the bump stop suggestion.
bayoujk's Avatar
Damn. No sway bar rubbage turned hard over. Or do u guys limit the steering
Old Oct 30, 2011 | 02:22 PM
bayoujk's Avatar
Oh tires will be 37x13.50 xterrains.
Old Oct 30, 2011 | 02:37 PM
fadeout's Avatar
I doubt you'll rub. You have the correct backspacing and clearance for a good amount of flex with 37's.
Old Oct 30, 2011 | 02:41 PM
bayoujk's Avatar
Cool! Well a guy offered me cash+37's for my 35's so I wanted to make sure before I swapped. Really want the bigger tires. I feel like I have too much fender well.
Old Oct 30, 2011 | 02:47 PM
bayoujk's Avatar
Yes tires are brand new but they shrank when I cut the fenders!!! Lol now I feel the need for 37's an I can't shake it!!
Old Oct 30, 2011 | 03:55 PM
bayoujk's Avatar
Did disconnecting the sway bars make it worse?
Old Oct 30, 2011 | 04:01 PM
sringer's Avatar
Usually, yes. When you disconnect you can flex more...which means it will rub on more. Unless you have proper clearance.
Old Oct 30, 2011 | 04:09 PM
jaker t5's Avatar
I rub at full turn with 37/13.50 I didn't when I had 35/12.50 , I have been thinking of getting wheel spacers just have not figure if I should do it
