4" lift and ESP issues
Old May 6, 2009 | 10:46 AM
Goblin's Avatar
Default 4" lift and ESP issues
Ok I installed 4" lift ( stock 16" tires with BFG mud tires ) for 2 weeks after the lift no ESP issues at all ( believe me I tried to set it off) now all of a sudden after about 1K miles later I now have the ESP going off during freeway on/off ramps. What could be causing this ?
steering wheel is still centered, nothing has really changed except one of the rear tires may have a bit more wear than the other ( moved front to back and one was wearing funny, its rounded out nicely now but may have lost a bit of tread depth in the process)
Only during on/off ramps and more so at lower/moderate speeds
Any Ideas ?
Thanks,
Goblin
Old May 6, 2009 | 10:57 AM
mkjeep's Avatar
After my lift had settled in , got the same thing. Put frt lower adj arms on and I really have to push it to get the ESP to kick in. The more your suspension is dialed in , the less probs you'll have.
Old May 6, 2009 | 11:16 AM
Goblin's Avatar
Default Tnanks
for the input !
Was it just the lower adj bars you put in or did you do upper as well ?
Old May 6, 2009 | 11:19 AM
RedneckJeep's Avatar
Yeah...did you really expect to lift your Jeep 4" and have no ill effects?
Old May 6, 2009 | 11:58 AM
texasman1383's Avatar
I'm lookin at puttin a 4.5" lift on my unlimited which also has a 5.7 hemi any advice as far as a good company with lifetime warranty on hard parts
Old May 6, 2009 | 12:12 PM
mkjeep's Avatar
Originally Posted by Goblin
for the input !
Just the frt lowers
Old May 6, 2009 | 12:13 PM
Goblin's Avatar
Default No
No, I expected it to blow up.... thanks for the constructive insight
