4" lift help
Old Mar 10, 2011 | 03:28 PM
jstrong394's Avatar
Default 4" lift help
Okay wife wanted the 2.5 bb then stock now 4" lift. So what is the best 4" lift for under 800..... Also how hard to install, what kinda time does it take?
Old Mar 10, 2011 | 03:58 PM
nthinuf's Avatar
There is no 'best' for under $800, there is just 'will do the job'.
Install time and difficulty will depend on which components are in the lift. If it is just coils and brackets, should be about the same as your 2.5".
Open the faq's stickied to the top of this modified area and look in the suspension section. You will see the recommended components for 3" and 4" lifts. You ain't gonna get them with your budget. So learn what all of the components do, do a little research into the lifts in that height, and decide which has a setup you can live with.
Old Mar 10, 2011 | 04:02 PM
07JKDakotaEd's Avatar
My advice, do it right.
Old Mar 10, 2011 | 04:36 PM
Get a 2.5 bb with a 1.25 body. 3.75 inches of lift close enough to 4 inches
Old Mar 10, 2011 | 05:10 PM
jde164's Avatar
Originally Posted by TheDirtman
You could put some flat fenders on there, it will give you the look of a 3"-4" lift.
This shot is stock suspension with bushwackers flat fenders and 33" tires.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=136167"/>
I like this idea.......pondering doing this for the non wheeling jeep.
Old Mar 10, 2011 | 05:19 PM
Harbourone's Avatar
Plenty of you folks have opinions on what a person needs for a lift of a certain height. How many of you have the experience of driving various heights without 5000$ in suspension add ons?
Ive got 10000 miles on ome hd springs with 1" poly pucks from tf and lt shocks. No ca's, no fancy flip kit, high steer kits ect. It drives fine. Factory drive shafts, factory arms.
All I've got is the minimum. Extended brake lines, extended bump stops, and trac bars. My axles were wayyyy out of line.
Driving is a little touchier, but it's not too bad. I've done well over 600 miles in a day and it didn't bother me.
I think I'll be using aev control arm relocation brackets. I don't have the $$ for a bunch of ca's right now.
Old Mar 10, 2011 | 05:42 PM
betjeep09's Avatar
That may be fine for you, but I would not put my wife and family in a vehicle that questionable with flighty steering and most likely some pretty good bump steer. I would think you as a paramedic would see the danger in that.
We are all putting our lives at risk every time we hop in a car, whether it's a Volvo or a Jeep.
Old Mar 10, 2011 | 05:57 PM
nycvr6's Avatar
TF 2.5" BB, 1.25" BL, 35's and chopped fenders. Nice and cheap, I drive 99% of the time in NYC, and it drives just like stock.
Old Mar 10, 2011 | 06:47 PM
Harbourone's Avatar
You have proved my point you have around $1100 in the components that you mentioned and it is incomplete with some flighty steering. When your driveshafts go out there will be another $1000, $500 for a couple of sets of control arms, drag link flip to correct the bump steer at $300-$500 and it adds up. And just wait till you bend those axles running those big tires on a weak dana 30.
The axle is already planned to be replaced with an atomic 60. It's needed as I'll be on 37's soon (they're in the garage) with just gussets, and 40's in a year or two.
The drive is safe, it just wanders a small amount. No terrible bump steer. Definitely not as much as my old diesel dually.
I believe my family is very safe in my jk, aside from the weak factory cage. I also think that aev's drop brackets are fine for 95% of us on here. I know I don't need that extra clearance where I wheel. Mostly snow/mud.
