4"long arm kit with 37or 35?
Old May 23, 2014 | 06:51 AM
Cwalden81's Avatar
Default 4"long arm kit with 37or 35?
I everyone I'm looking into the rough country 4" long arm kit on my 2008 JK Rubicon and 37 or 35 with the proper gearing. My question is will the stock axles on the Rubicon hold up to 37?
Any advice would be much appreciated.
Old May 23, 2014 | 08:50 AM
Rob 12B1P's Avatar
I blew up the front axle and bent a rear with the stock 32's. It really depends on how hard the obstacles are you are willing to go for.
Old May 23, 2014 | 11:09 AM
Tooadvanced's Avatar
99.9% of ppl with be fine with the Dana 44's and 37's. Make sure u gusset the c's with 37's. And maybe sleeve it
Old May 23, 2014 | 11:30 AM
GreatWhite JK's Avatar
I everyone I'm looking into the rough country 4" long arm kit on my 2008 JK Rubicon and 37 or 35 with the proper gearing. My question is will the stock axles on the Rubicon hold up to 37? Any advice would be much appreciated.
my 38X14.5 are still running strong on my stock 44s so you'll be fine unless you act like your jeep is a rock bouncer...
Old May 23, 2014 | 12:49 PM
Cwalden81's Avatar
Thank y'all for the info looks like 37 13.50 it is
Old May 23, 2014 | 06:09 PM
Im still running my stock 4:10 because once you go 5:13 or higher the ring gear and pinion gets smaller and weaker...
*only mentioned this because you talked about gearing above*
Old May 23, 2014 | 06:15 PM
TheDirtman's Avatar
Very few people break ring and pinion due to the gear ratio. Running proper gearing will releive the stress off the entire drivetrain and will allow you to go slower thru more techinical driving.
Old May 24, 2014 | 06:36 AM
Cwalden81's Avatar
With running 37 with the automatic I am going with 5:38. I learned with my last truck that gearing is very important
Old May 24, 2014 | 06:47 AM
TheDirtman's Avatar
I would replace the rear factory axles with cromoly shafts as the factory ones are famous for breaking right at the splines.
Old May 27, 2014 | 05:59 AM
WARLOCK's Avatar
even with 35 I would suggest to replace axles with cromoly ones, put inner sleeves and C gussets. a Rubicon axle is not stronger than any other stock JK axle and they are weak for tires above 35''
somes will say that stock axles are fine with 35 or 37 but the driver and purpose might be a limiting factor.
