40s on factory Rubicon axles?
Old May 1, 2012 | 01:02 PM
Ajohnson0830's Avatar
Default 40s on factory Rubicon axles?
Anybody running 40s on their Rubicon axles. I've got upgraded axle shafts but don't have the money to put 60s on (the tires are expensive enough!!!)My feeling is to stick with 37s to be safe but I'd appreciate the feedback.
Thanks!
Old May 1, 2012 | 01:17 PM
wayoflife's Avatar
JK-Forum Founder
i've tried it and now run dynatrac pro rock 60's. if you use your jeep, you're better off sticking with 37's. hell, i even broke my 44's running them.
Old May 1, 2012 | 01:35 PM
Great thanks for the help
Old May 1, 2012 | 05:04 PM
superjk10's Avatar
You broke the stock axel shaft or a chromoly?
Old May 1, 2012 | 08:22 PM
CALIJK's Avatar
Only running 39's, not 40's, but just broke my stock rear Rubi 44 in Moab. I knew it was coming, but wish it wasn't at the end of the very first day.
Old May 1, 2012 | 08:29 PM
FlameRedJK's Avatar
You're not exactly normal though lol
Either way, sounds like a bomb waiting to go off.
Old May 1, 2012 | 09:02 PM
69mach1's Avatar
Cool
Nuts! Did you break an axle or the Rubi E locker? and does that mean driving back with front wheel drive? Hope all goes well with the repair
Old May 2, 2012 | 02:19 AM
Jeter's Avatar
I am running the 39 krawler on Front Rubi axle and non rubi rear 44. I have an RCV in the front with an external sleeve on the tubes. I Run the superior 30 spline rear chromo's with an arb locker and have a truss on the rear to help with deflection. I am going to upgrade to the 35 spline arb and 35 spline axles because I have been breaking the rears. I beat on mine pretty hard in the same kinda crap that you would be wheelin in. I think you would be fine as long as you build it correctly or if you don't wheel it hard. I would love to have a 60 front and a shaved 14 bolt in the rear but it is kind of expensive. But hell it's kind of expensive either way.
Old May 2, 2012 | 05:33 AM
tattedfire's Avatar
I believe Eddie (WOL) has broken both. A front chromoly I know for sure
Old May 2, 2012 | 06:10 AM
wayoflife's Avatar
JK-Forum Founder
what he said, front chromoly at the shaft, NOT the u-joint and while just running 37's. running 40's on a factory sahara 44 with 35 spline shafts, i've blown out a rear r&p but then, it was a 5.38 and knew it would go sooner than later. i've also managed to break a rear chomoly semi-float 60 shaft running 40's and, is why i now run a full-float pro rock 60.
