410 and 35's
Old Dec 3, 2008 | 11:14 AM
jtwjk's Avatar
Default 410 and 35's
i want to get new tires but should i get 33 or 35 did anyone lose that much performance going from 33 to 35. im afraid i will get the 33 and want 35 but afraid of the power loss here in western pa and the hills we have . i have a 07 unlimited with 410 and 265 75 16 right now and a 2 in full traction lift thanks
Old Dec 3, 2008 | 11:26 AM
scouter4life's Avatar
Go with the 35's, the 4.10's are more than capable for them. You never hear anyone say, "I wish I had smaller tires".
Just to confirm, do you have an auto or Manual?
guinnessisgood's Avatar
With 33's I am considering going with 4.56 gears. I think most people here would agree that you should go higher then 4.10 gears if you are putting 35's on there.
Old Dec 3, 2008 | 11:30 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
4.10's and 35's are not that bad. that is what i was running until i went to the 5.13's. OD still works on the flats but any kind of grade and you can forget about it.
Old Dec 3, 2008 | 11:32 AM
lijeepguy's Avatar
i just put 35s on my 07 unlimited with the factory 410 gears , its not to bad , you will have to turn off your overdrive it is useless with the 35s, im going to be upgrading to 513s in the future , , but it can be done , no problem , you just loose a lil more on your take off and you lose your o/d ... p.s the 2 in lift will be tight , and if you plan to wheel the JK disconected you will rub your fenders
Old Dec 3, 2008 | 12:32 PM
Windrocker's Avatar
No question about it, go with the 35's. Here in the hills of Tennessee I do turn the overdrive off any time I am going up a hill of any length, but other than that the 4:10's will peform fairly close to stock.
Old Dec 3, 2008 | 12:34 PM
Leonard Massi's Avatar
I have 35's and I've done just the bolt on stuff with the motor. I have plenty of power and no problems on the trail getting where I need to go.
Old Dec 3, 2008 | 02:33 PM
Smoke6's Avatar
I'm runnning 35s and 4.10s. No complaints here.
Old Dec 3, 2008 | 02:37 PM
jckid's Avatar
I have 4.10's and honestly I'd have to think twice before even going with 33's, but I do use the JK to tow. If you don't tow, 33's would probably be fine, but I think it would be a real dog with 35's and 4.10's.
Old Dec 3, 2008 | 03:12 PM
Spytec128's Avatar
Veteran: Navy
I say upgrade you gears to 5.13's and get 37's!!!!!
