410-513s
Old Mar 12, 2010 | 07:34 PM
rhino4bs@yahoo.com's Avatar
Default 410-513s
how much weaker is the 513 gear set i have herd they are
Old Mar 12, 2010 | 07:35 PM
CerOf's Avatar
The pinion will be smaller, but I think the weak link would be elsewhere still.
Old Mar 12, 2010 | 07:58 PM
Stuka's Avatar
The pinion gets TINY. Its significantly weaker than a 4.10 gear set. If you look around a bit on here, you will come across several post of people blowing their 5.13 gear sets. I still stand by not going lower than 4.56's with a D44.
Here are the tooth counts (these do vary by manufacturer):
4.10
Ring: 41
Pinion: 10
4.56
Ring: 50
Pinion: 11
4.88
Ring: 39
Pinion: 8
5.13
Ring: 41
Pinion: 8
And, here is a photo of a factory JK 4.10 next to a 4.88:
Old Mar 12, 2010 | 09:23 PM
JayhawkJeep's Avatar
Veteran: Navy
Originally Posted by planman
I don't recall reading many, if any, failures of properly installed 5.13s. Where are all these posts of properly installed 5.13s blowing?
In fact, when WOL had his catastrophic front axle failure, his chromoly front axle shafts failed prior to his 5.13 gears. When he had rear axle failures, the stock Rubi locker failed before his 5.13 gears.
Chromoly axle shafts and stock Rubi lockers are weaker than properly installed 5.13 gears.
We just pulled the 5.13s out of my wife's 4 dr Rubi on 37s to install 5.38s--without any hesitation.
+1 I don't seem to recall anyone blowing a set of 5.13's. If there are some threads please direct me because I would like to read them.
Old Mar 12, 2010 | 09:48 PM
Stuka's Avatar
WOL has gone through two sets of rear R&P's. I know TrailBud has also gone through a set. Do a search and you will see others. I am also going with experience in other non-JK rig's with rear D44's. Typically the fronts don't go because they have far less strain on them. The rears have most of the weight of the vehicle when climbing a hill.
This is one of the rears people go with Ford 9's in TJ's in back, it has a pinion support and a huge pinion compared to a D44. Its also one of the biggest things you gain when going with a D60.
EDIT:
TrailBud breaking his: http://www.youtube.com/watch?v=AOrY8roQ774
Old Mar 12, 2010 | 09:56 PM
Chicken Corners's Avatar
X2, heck, i do not recall any threads of 5.38s blowing up.
Old Mar 12, 2010 | 10:25 PM
nthinuf's Avatar
He was running 40's at the time though, wasn't he?
I'd suggest qualifying any of the people blowing up gears, taking into account any other circumstances involved. Hemi? Lead foot in the rocks? Pushing 40+ inch tires?
Personally, I wouldn't compare someone with 35's, a stock engine and a light foot blowing up gears to someone with a hemi and 42's. A mild build and a light foot, and you shouldn't need to worry much about the gears. Big tires and romping up through the rocks, and ...
