48" or 72" jack
Old Feb 25, 2011 | 03:35 AM
fisterc's Avatar
Default 48" or 60" jack
I have a 6" lift on 35" tires. Would I need to invest in the 60" jack in order to change a tire to make up for the difference in the lift?
Last edited by fisterc; Feb 27, 2011 at 04:37 AM. Reason: Realized there was no 72" jack...
Old Feb 25, 2011 | 04:09 AM
westchester's Avatar
Originally Posted by FFA_nsk
High lift jacks are not for changing tires
x2 a bottle jack, or the stock jack with a lump of lumber is much safer.
However, Ive used my Hi-lift to change a tire and I was 2/3 up on my 72" Hi-Lift to get wheel sufficiently off the ground (didnt bother to tie the suspension). Of course, it depends where on JK you attach the Hi-lift.
Hardest part is finding a safe place to store the 5ft Hi-lift. The extra 12" makes it near impossible to store inside JK, or vertical.
Here's mine
Old Feb 25, 2011 | 04:20 AM
fisterc's Avatar
Thanks for the input.
Old Feb 25, 2011 | 05:41 AM
Just realiszed, most of us (including me) cannot add. 5ft = 60", not 72".
Old Feb 25, 2011 | 05:47 AM
Rafi's Avatar
i was just gunna say i didnt think they had a 72" thought it was either 4 or 5 footer.
48 or 60
Old Feb 25, 2011 | 06:57 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Buy a 4' and one of these...http://rimrockmtn.com/products.htm#Jack
Old Feb 25, 2011 | 08:06 AM
LBJEEPER's Avatar
I'd say go for the 60". I did and if you store it running width-ways its fine. You can do some fine tuning adjustments to keep it from sticking out on either side of the jeep. And if you buy the 48" you'll probably just want to upgrade later and why spend the money twice?
