5.13 or 5.38
Old Feb 16, 2011 | 03:33 PM
Birdog3's Avatar
Default 5.13 or 5.38
im getting ready to install 37 , my JK is my primary , but plan on getting another truck . i have a 6-speed rubicon and wanted some feed back on you guys that are running the same set up . thanks:
Old Feb 16, 2011 | 05:24 PM
woodweavil's Avatar
im running 5.13s in a 2dr with 37s with auto! no problems what so ever! but with the 35s it was overgeared and my MPGs suffered. if your running a manual unlimited i wouldnt go any lower than 5.13s! 538s will have you overgeared and you wont like the results in the wallet for fuel! if your manual do you have 3.21s? you could always go with a thick gear and keep the smaller carrier
Old Feb 16, 2011 | 05:29 PM
woodweavil's Avatar
Originally Posted by TheDirtman
Did you even read the OP?
yes I did!!! just my opinion is that not what the op asked for ?
Old Feb 16, 2011 | 05:49 PM
woodweavil's Avatar
Why ask if he had an auto and 3.21 gears when he states in the OP that he has a rubicon with a 6 speed?
I didnt ask if he had an auto i said I do! I saw that he has a manual and that is why I said that! as for the 3.21s i dont know what his gearset is for a manual! that is why i asked. why dont you worry about your posts and not mine!
Old Feb 16, 2011 | 05:54 PM
nthinuf's Avatar
Will the truck be the tow vehicle, making the JK your off-road only toy? Or will the JK be used for freeways to and from the trail? How much freeway time will it see, and how far? Do you play in the rocks, and is pinion size a concern? Any plans of going bigger than 37?
As noted above, 5.38 may not be your best choice for a manual. 4.88 and 5.13 are very popular for that setup.
Old Feb 16, 2011 | 06:14 PM
woodweavil's Avatar
As noted above, 5.38 may not be your best choice for a manual. 4.88 and 5.13 are very popular for that setup.[/QUOTE]
my point exactly!!
Old Feb 16, 2011 | 06:21 PM
Birdog3's Avatar
thanks for the advice i was leaning toward the 5.13s its just the JKs have no bottom end and im worried about it in those tight crawling positions. yes i will be getting a tow rig.
Old Feb 16, 2011 | 07:50 PM
BKGM Jeepers's Avatar
I run 37's and a 6-speed with 5.13's. I'd get 5.38's if I had it to do over again because my 38's go on tomorrow.
Old Feb 16, 2011 | 09:10 PM
KenB1010's Avatar
I currently run 5.13s with 37's on a 6 speed. It's perfect on the highway, but lugs on the mountain roads. I wouldn't go to 5.38's on a D44 though. Way too many people have broken their pinion gear.
Old Feb 23, 2011 | 10:57 PM
Jeep Hound's Avatar
Have you ever run 35's with your 5:13 gears?
Reason I ask. I have a 6sp 2 door and have 35's now but don't plan on getting 37's till my 35's wear out. I have 4:10 gears now and my jeep is gutless!! Like pulling a trailer everywhere I go. How bad would 5:13's be with 35's?
