5.13 gears
Old Feb 16, 2011 | 02:36 PM
Default 5.13 gears
Those of you running 5.13 gears on your Rubicon, what engine rpm are you turning at 70mph? How about gas mileage?
Old Feb 16, 2011 | 02:40 PM
troyboy's Avatar
Take a look at the FAQs. There is a chart in there that will tell you the RPMs at 70mph depending on the gearing and tire size.
Old Feb 16, 2011 | 02:46 PM
troyboy's Avatar
The RPM chart is here:
https://www.jk-forum.com/forums/show...l=1#post211276
Old Feb 16, 2011 | 02:48 PM
nthinuf's Avatar
And be sure to go outside and measure your tires - do not use the mfg's spec.
Old Feb 16, 2011 | 04:01 PM
woodweavil's Avatar
im running 37" km2s on 5.13s and 70 mph nets a whopping 2250 rpms with the aev procal tuner set for 35s , and I might add I average 18.1 mpg thats the math not the gauge.
Old Feb 16, 2011 | 04:38 PM
07 JK "bullfrog"'s Avatar
Hey!!! Quick tire question for ya! Ur km2's. How wide are they? 12.5 or 13.5? And is that ur daily driver? :random, sory
Old Feb 16, 2011 | 04:40 PM
18.1 mpg! Damnn! That's better than my 07 silverado!
Old Feb 16, 2011 | 04:45 PM
lovehate's Avatar
18mpg!...Is this with a 6 speed? And a tune set for 35s..does that help to increase mpg r was that a typo?....Thanks
Old Feb 16, 2011 | 04:56 PM
Km2 tires measure less than what they are. It may state 35 on the tire but actual size is 33.5 or something like that. So a 37 may be close to 35
Old Feb 16, 2011 | 05:04 PM
woodweavil's Avatar
they are 12.50s and yes it is my daily driver and yes it is less than its just over 35 . and its an auto . I noticed that when I changed from my 35 mud grapplers that are actually 34, to the 37s it was a few weeks before I could change the setting due to a faulty tuner. I actually at one point got close to 22 mpg. I was on a road trip from indiana to oklahoma and my speed was set at just over 60. so play with the setting to get max power and mpgs
PS your speed is the key!!!! 70 will get you around 17.5 to 18 + , go up to 75 or 80 and it drops drastically 13.5 to 14.8
