5.13 Gears 37inch MTR shifting issues
Old Jun 27, 2014 | 10:11 AM
aapfelbaum5's Avatar
Angry 5.13 Gears 37inch MTR shifting issues
I just recently changed to 5.13s and 37inch Wrangler MT/R W/Kevlar. I have a BullyDog GT Tuner that is set 5.13s gearing and 37.2 inch tires on the stock setting. I have noticed shifting lag on inclines and on the flat it seems to shift early. I find that often I have had to feather the throttle to get it to shift. Has anyone experienced this? It is starting to become annoying.
Old Jun 27, 2014 | 10:32 AM
Jade_Monkey07's Avatar
Dont the mtr's measure smaller than 37? Try dropping it to a 36.5
Stay muddy my friends
Old Jun 27, 2014 | 10:47 AM
drenton's Avatar
Similar set up but used AEV Procal. Entered my tires at 36.75. I note the same thing with the shift points particularly at interstate speeds.
Old Jun 28, 2014 | 01:37 PM
Thanks for your input. I will try lower settings over the weekend and hopefully get better results.
Old Jun 28, 2014 | 01:57 PM
K9wells's Avatar
I actually disconnected my battery when installing my snorkel I am running the Bully Dog Gt with 35" MT/Rs before disconnecting the battery it would hard shift after i disconnected it for several of hours i found that it shifted smooth again. Could be coincidence I dont know but worth a shot
Old Jun 28, 2014 | 02:43 PM
jnabird333's Avatar
Yes. I had to enter 35.5" to get my speedo to match my GPS speed. Yet I measure 36.25" with a square and tape measure???
Old Jun 28, 2014 | 03:32 PM
I found data that claims the Good Year MT/R 37s are actually 36.8. The Bully Dog does not have a setting to 36.8 so I set it to 36.77 and it seems to shift better without the need to feather the throttle. Thanks for the input.
Old Jun 28, 2014 | 05:23 PM
jnabird333's Avatar
The 36.8 is the unloaded height when mounted on a nominal wheel width. You should use the measured diameter once on the Jeep for the best shifting and most accurate speedo
Old Jun 28, 2014 | 07:39 PM
T&ERun's Avatar
Measure from the ground up to the center of the wheel. Multiply by two and that's gonna get you very close. Can't beat using a GPS to dial it in though.
Old Jun 28, 2014 | 08:46 PM
36Fan's Avatar
I got the same thing. Unfortunately the Flashcal and my 14 don't work together.
