5:13's... Do I need anything else???
So I'm going to eventually regear to 5:13's and was wondering if there is anything else I need to upgrade of beef up along with the new gears? I'm running an auto with 3:73's right now.
Staying with 33's?
There are some known weak points on the front axles. May not be needed, but might be a good call if you are in the mood to do some welding. - C gussets and reinforcing the trackbar mounts would be a decent place to start. May some control arm skids. Next step would be inner and/or outer axle sleeves and/or a truss. Chromoly or rcv axle shafts. Pro steer ball joints. Manual hub conversion.
Or scrap it and grab a ProRock.
Just depends on your budget and how you plan to use it.
i was also wondering this, but i currently have 35's and was goin to 37's but mine is a 6spd and 3.21's
i was told by a couple of people that i would need a larger carrier to do the 5.13's, is this true?
I remember seeing something about that as well, but I'm running 3:73 and didn't read into it too much. check under the Sponsor forum and find where Northridge was advertising their gears or call/email David and Northridge and he'll tell you. I remember him addressing it in the thread.
This should answer all you gearing questions..
https://www.jk-forum.com/forums/jk-write-ups-39/gearing-82262/
Incidentally, my installer said that my spider gears wouldn't fit the new carrier. They had some in stock that did. I've never heard of anyone else having that issue.
You'll love the 5.13's.
Yes. I got my D30 carrier from David @ Northridge.
David
And, honestly, the JKS track bar brace is worth every dime (heavily reinforces the weak stock track bar mount @ the axle, as well as the tube in an area shown to be prone to break).
If you have money left over when you're done, an Aussie Locker is HUGE bang for your buck.
