5.38 gears
Old Oct 8, 2009 | 07:04 AM
Default 5.38 gears
i just got my jeep back today after getting a d44 up front and 5.38 gears front and back. i took it around the block real quick and it seemed to have a bit more pep than before, but my question is where is the difference most noticeable?
people talk about gearing being the best bang for your buck you can get. it just wasn't quite as big of a change as i had expected. i'm at work and i can't take it up to 70 mph like i want, so i'm wondering what other people have experienced with gearing changes that makes it so awesome. i mean my bill is gonna be like 3400 bucks here so i'm hoping i didn't waste too much cash
Old Oct 8, 2009 | 07:08 AM
hvilla's Avatar
I'll be waiting to hear the opinions of the experts on this matter as well...
Old Oct 8, 2009 | 07:15 AM
did you look at those speed/rpm charts before doing this, 5.38's aren't for a highway rig
Old Oct 8, 2009 | 08:00 AM
meatsandwich's Avatar
I just pulled the trigger on 5.38's today
My Auto/4 door/ 4.88 combo was OK for the Colorado Passes, but sucked on flat highway. The tranny could never decide between OD and 3rd
The RPM chart listed above with Auto/ Manual is the key while planning for future mods.
(Paying big $$$ for the same parts twice sucks)
Old Oct 8, 2009 | 08:33 AM
they are if you have an auto like i do
Old Oct 8, 2009 | 08:41 AM
nthinuf's Avatar
with the 3.8L V6 JK engine.
JK's are poor enough performers bone stock. (speaking more of auto's here, since I've never driven a manual) Add in a lift, bigger tires, armor, etc, and how can anyone possibly expect new gears to perform miracles? The folks that say gears are the best 'bang for the buck' are right, as it is the best way to offset all the mods. You just can't confuse new gears with an expectation of instant v-8 power.
Old Oct 8, 2009 | 09:01 AM
Originally Posted by planman
Not sure where you got that idea--unless you are looking at the generalized charts that do no match our engine torque/horsepower curve and transmission gearing.
With an automatic and 35s with 5.38s, your rpms are 2495 at 70 mph.
That is perfect for a highway rig with the 3.8L V6 JK engine. Your gas mileage would likely be around 18 at that rpm and your rear wheel horsepower at that rpm should be enough to avoid downshifting on hills and in windy situations.
With a 6 speed and 35s with 5.38s, your rpms would be 3038. That would be a little high. Your gas mileage would probably drop to 14 mpg.
Here is a correct chart:
can't see the chart but is the over drive that much different from auto to manual?
Old Oct 8, 2009 | 09:06 AM
nthinuf's Avatar
42RLE—Automatic, Four-Speed Overdrive
Gear Ratios 1st 2.84
Gear Ratios 2nd 1.57
Gear Ratios 3rd 1.0
Gear Ratios 4th 0.69
Gear Ratios Reverse 2.21
Axle Ratio 4.10
Overall Top Gear 2.83
NSG 370—Manual, Six-Speed Overdrive
Gear Ratios 1st 4.46
Gear Ratios 2nd 2.61
Gear Ratios 3rd 1.72
Gear Ratios 4th 1.25
Gear Ratios 5th 1.00
Gear Ratios 6th 0.84
Gear Ratios Reverse 4.06
Axle Ratio 3.21 Std., 4.10 Opt. (Std. on Rubicon)
Overall Top Gear 2.69 Std., 3.44 Opt. (Std. on Rubicon)
Old Oct 8, 2009 | 09:08 AM
BPMOTO505's Avatar
I have ran 4:88s and now have 5:38s and wouldn't even dream of going back! With 4:88s I couldn't hold overdrive with any wind at all. We just have to realize the 3.8 is under powered for the application. This vehicle should have had a small v8 from the factory.
Old Oct 8, 2009 | 09:25 AM
spinlock's Avatar
I am running 5.13s on my Sahara and I certainly noticed when moving up from the stock 3.73s. Maybe it is because I ran on the stock tires for a while, but the performance with 35s is better than it was with 3.73s and the stock 32" tires. Oddly enough I didn't notice much difference in shift points or anything else when I recalibrated the PCM with a Procal for gearing and tire size.
With the 3.73s I was not comfortable pulling out into the fast lane on a grade, but the 5.13s its not a problem unless the JK is heavily loaded.
I chose the 5.13s because I didn't want my RPMs to fly above 3500 if I dropped out of overdrive while driving 75-80 MPH (which I would obviouslly never do ) . But besides that, I could definitely use the additional RPMs provided by the 5.38s in the city and offroad.
I certainly support the statement that "gearing is the best bang for the buck". Maybe you just need the gears and the new axle to break in.
