5.38 questions
Old Dec 26, 2011 | 09:15 AM
dlincoln91's Avatar
Default 5.38 questions
I have some quick questions before i order my 5.38 gears. This has nothing to do with my front axle because i have a custom 60 with 5.38 gears already.
I was wondering does it matter which gears i order if i am not running a rubicon rear-end?
Also where are yall ordering your 5.38 gears from and i have already had 1 gear change should i still order a master overhaul kit for the 5.38s change?
thanks
Old Dec 26, 2011 | 10:03 AM
Rockstar007's Avatar
thanks
doesnt matter which gear set.....
The Off Road Connection is where I order my gears from.
I would order a master kit each gear change..
Good Luck!
Old Dec 26, 2011 | 12:19 PM
BadPunkin's Avatar
I went through Northridge and would do an overhaul kit.
Old Dec 26, 2011 | 01:26 PM
SergeantChuck's Avatar
I was recommended to me to purchase over kit because some place may not warranty the work with only a ring and pinion change. You should check with installer.
Old Dec 26, 2011 | 01:47 PM
Mark's Avatar
5.38 will not work in a non-Rubi 44. Youll have to replace something called the "cage" to get them to fit. Though I must say i havent met anyone who has done this. and X2 on getting the rebuild kit when changing the gears.
Old Dec 26, 2011 | 03:15 PM
dlincoln91's Avatar
i dont see why they wouldnt fit but i will talk to david tomorrow
Old Dec 26, 2011 | 08:47 PM
drivingfool's Avatar
OP has a 60 up front, that's plenty big enough for the 5.38 I believe.
Old Dec 27, 2011 | 05:47 AM
dlincoln91's Avatar
if you read the first post it says this is for the rear not the front. the front is already geared but thank you for the input
