5.48" backspacing
Old Apr 2, 2010 | 11:57 AM
gongetya's Avatar
Default 5.48" backspacing
Does anyone know if a wheel with 5.48" backspacing will work without mods? I have 35x12.5x17 tires on the stock moabs now
Old Apr 2, 2010 | 11:58 AM
JayhawkJeep's Avatar
Veteran: Navy
Generally you need 4.5 or less to not have to run spacers.
Old Apr 2, 2010 | 12:01 PM
BLK-JK23's Avatar
i have 5.5... with 33's no rubbing at all you'll be fine..
mine are 16's
Old Apr 2, 2010 | 12:03 PM
Veteran: Navy
mine are 16's
I have found it is more about width then size. What width you got on your 33's?
Old Apr 2, 2010 | 12:06 PM
gongetya's Avatar
thanks for the fast response yall
Old Apr 2, 2010 | 01:58 PM
spinlock's Avatar
x2. Tire diameter is not the issue, it is tire width. If you read the FAQ you will find that you need spacers or 4.5-4.7" max of backspacing to clear 12.5" wide tires from interference at full turn.
