538s going on in the morning
Old Aug 25, 2010 | 02:30 PM
HV's Avatar
HV
Default 538s going on in the morning
any advice on the break in and any other things I should know . I am getting 538s installed in the morning
thanks
Old Aug 25, 2010 | 02:35 PM
wvhasty's Avatar
Most conservative advice I have come across is:
1. For 1st 15 minutes run surface street speeds
2. Let rest for at least an hour
3. Repeat 1 & 2
4. For balance of 500 miles:
4a. No towing
4b. No aggressive acceleration
4c. Avoid highway speeds
5. After 500 miles:
5a. Remove diff covers (Drain fluid)
5b. Inspect for proper wear pattern - I have the installer do it
5c. Re install covers, refill, and enjoy
Old Aug 25, 2010 | 03:12 PM
vegasoutlaw's Avatar
You planning on going to a larger tire?
Old Aug 25, 2010 | 06:31 PM
HV's Avatar
HV
I have 35s now might go to 37s or higher
Old Aug 26, 2010 | 06:30 AM
crowsjeep's Avatar
Let me know what you think of them, mine will be here today, and going on next week. I found a place in Ogden that will do them both for $600. Problem is, I will have to drive at highway speed right after they go on.
Old Aug 26, 2010 | 06:35 AM
dmhines's Avatar
Who is doing yours?
I had 4 wheel parts do mine last week. They gave me a check list similar to above ... Also ... I have to bring my JK into the shop at 500 miles so they can remove covers, drain fluid and make sure everything looks good.
Old Aug 26, 2010 | 01:06 PM
HV's Avatar
HV
I will let you know once I pick it up from the shop
Old Aug 26, 2010 | 01:56 PM
CrazyCasey's Avatar
3. Repeat 1 & 2
4a. No towing
5. After 500 miles:
Step 5 is not nessacary if they are installed properly. a reputable shop that knows jeeps and knows how to properly install gears will do it right. You dont have to drain the fluid 500 miles after you buy a new one!!!!! I guess most people do that just to be on the safe side!!!!
YOUR GONNA LOVE THE 5.38s
