5x4.5 to 5x5 wheel conversion???
Old Oct 21, 2007 | 05:11 PM
Henri's Avatar
Question 5x4.5 to 5x5 wheel conversion???
So I have 5 Bfg 33x12.5 on/American Racing AR-23 15X8 5X4.5 3.75 BACK SPACE 23-5865. The tires are still new, cuz I only had em for 3months on my old TJ. If I got the wheel adapters from Quadratec do you think it would fit on my 07JK? Would they rub on anything? Brake lines, fenders, etc?
Thanks,
Henri.
P.S. Adapters link from Quadratec
http://www.quadratec.com/products/92807_006.htm
Old Oct 21, 2007 | 07:33 PM
wayoflife's Avatar
JK-Forum Founder
Actually, with wheel adapters, you should have more breathing room than without them. If anything, your wheels will stick out quite a bit past the flares.
Old Oct 22, 2007 | 12:09 PM
Henri's Avatar
Yeah but would it be a problem for the engine as far as stress goes? Do you think it would be a big change in handling?
Old Oct 23, 2007 | 02:53 AM
degenerate's Avatar
you are going to have a huge turning radius. you are adding somewhere in the neighborhood of 3" on each side.
maybe a little more sluggish with the larger diameter and wider tire. do you have the rubi? if so, then the difference will be minimal.
have your dealer flash for the 32" rubi tire size.
Old Oct 23, 2007 | 06:20 AM
wayoflife's Avatar
JK-Forum Founder
Not at all. It would be no different than running aftermarket wheels with less back spacing.
