6' 4"...help needed
Old Mar 14, 2007 | 03:57 PM
y2ksir's Avatar
Default 6' 4"...help needed
Hey everyone, I have a question or two that hopefully you can help me with. I will be ordering my first jeep in the next few weeks (4 dr Sahara) and am already planning mods for it. Problem is that I live in a condo and my underground has a max height of 6'4". Anyone know what kind of lift/tire set up I can squeeze under there? I was hoping to keep something at around a ride height of 6'3" to allow for bumps and such in the garage.
Any advice and/or recommendations are greatly apprecieated.
Thanks guys!!!!
Old Mar 14, 2007 | 04:17 PM
possumface's Avatar
i may be in the same boat my garage door is of normal size but a lift with big tires could cause a problem and we wouldn't want to be parking outside..jeeps have been known to be on a car thefts menu
Old Mar 14, 2007 | 04:30 PM
101gargoyles's Avatar
Former Member
If your underground is anything like most I've seen there should be what we call in the construction industry 'bong bars' at the entrance. They are horizontal pipes suspended usually on chains at each end to allow some swing to minimize damage to a vehicle or load that contacts it in the event you're too tall to enter.If you own a building with suspended and exposed fire sprinkler pipes you'll understand how a couple hundred $ can save thousands!
That said when you recieve your much anticipated new ride head to the bar and stop under it and measure the clearance. The bar elevation 'should' already take into account bumps etc. if properly installed.
If it helps you at all - with our Unlimited Rubi stock, we keep away if it's posted at 6 feet.
Old Mar 15, 2007 | 04:39 PM
y2ksir's Avatar
Ya, I could do that but I wanted to order the tires/rims and install them as soon as I got the Sahara so that I could remove the stock ones and sell them as new. Being in Canada I will have to order the stuff and who knows how long that will take.
I wanted to make sure the stocks were in mint shape to sell 'em.
Old Mar 16, 2007 | 06:12 PM
RedRockJK's Avatar
Well I finally got a measurement for you. Best I can tell mine measures 6'3.5" (75.5") from floor to the highest point on the top. It is a hardtop though, and I think the soft top may sit up a little higher than that. I would think that would be too close to 6'4" to be safe.
Old Mar 16, 2007 | 07:22 PM
madirishman's Avatar
I can help as well. My Jeep JK with a 4" Superlift and 35" BFG MT on stock rims and it is 6'4".5 from ground to top of hardtop. I was worried aswell but just went for it. I have 3" before snags the garage door. hope that helps!!! Wish I would have went with 37's
Old Mar 16, 2007 | 08:39 PM
y2ksir's Avatar
well thanks for the help guys, as much as Id love too...its not worth the risk. I guess I will have to go with 33's and a 2.5" lift to be safe!
