8000lbs winch enough
Old Nov 19, 2007 | 12:02 AM
  #21
wgr's Avatar
wgr
Talking
Originally Posted by bofer84
Dude, no offense, but there is no way your jk weighs that much...my loaded F150 with 35s weighed a little more then that, and its way way heavier then the jk. Last time i put mine on the scales, it weighed in at 4200 i think...that was a while back, unlimited rubicon manual tranny. I am still under the impression that 10k and above is overkill and 8k lbs is perfect
Yes Sir, it might be overkill but for me it´s just perfect. Also in my second sentence i did say 9000 could be enough. Depends of...
Anyway this is how this should work here, opinions we have more than facts.
I am not hurt by this, just keep coming ! I am not right always and i am able to say you might be right. This is a great forum we have and lets keep it such way. I have learnt a lot from you guys and will hang around with my opinions. Try to bear me.
Old Nov 19, 2007 | 02:53 AM
  #22
RedRockJK's Avatar
an 8k lb winch is plenty. I got a 9k lb winch because I liked the brand and it was a good deal, not because of the higher capacity. Like several others have said, if you get an 8k lb winch be sure and buy a snatch block. That way you can double your pull strength if you ever needed to.
Old Nov 19, 2007 | 04:27 AM
  #23
ThinkMud's Avatar
so what does the gross weight mean? I'm confused now
Old Nov 19, 2007 | 08:08 AM
  #24
Blue's Avatar
Originally Posted by ThinkMud
The only weight that is listed inside the door jam? I believe it's gross, what's the difference?
That's gross weight on the door jam. That is the max the jeep is rated to carry including it, fuel, people, gear etc.
Old Nov 19, 2007 | 08:17 AM
  #25
ThinkMud's Avatar
Ok, then, well if our JK is really only 4,200 lbs, wow! That makes shopping for a winch a tab easier huh? 8k should be just fine.
so 4,200 * 1.5 = 6,300
so 8,000 lbs winch is all we would need.
Old Nov 19, 2007 | 08:18 AM
  #26
MJS_Jeep_888's Avatar
the stock base model unlimited X is 5,400 lbs. so heavily modified you are looking at over 6,000 lbs. maybe the 2 doors are only 4,500 lbs. don't know. but I have close 6,000 lbs in and on my 4 door now.
a rule of thumb I have always heard about a winch is get one that can pull 1.5 times the weight of your rig, and more if you play in lots of mud.
so 6,000 * 1.5 = 9,000 minimum.
This may be a good idea, but personally I think that this is overkill. Unless you're trying to pull in a situation where the object you're winching is trying to get away from you () then I don't think you need any more than your vehicle's weight. Will a beefier winch do a better job? Probably. But will a good winch roll over and die at its max rating? Nope.
Old Nov 19, 2007 | 02:07 PM
  #27
ESPMike's Avatar
Originally Posted by cormac827
either way...8k winch would most probably be fine, but if you're cautious you may want to get a 9, 10k.....mine is 10k gorilla....if youre looking for something decent cheap you might want to check that out.
think mud-got the liners in they are very nice.
How has that gorilla worked out for you so far? I was checking them out on Ebay, a 12000lb winch for $350? That has got to be too good to be true. Have you used it much? How did it hold up?
Old Nov 19, 2007 | 02:29 PM
  #28
cormac827's Avatar
well i didnt look on ebay, i went to their website, i did some research and was pleased with what i found, I was also told it was a good tough winch by a buddy (manufacturer) who has one and i can say they are very stout....im actually installing mine this friday morning along with bumpers and a snorkel, ill def let you know. Ill put some pics and stuff up also, but you can check out the site, the 10k is priced very reasonably...ill test it after the install and see what it can do also.
edit:looked on ebay and only saw their atv winches?
