81mm hub centric rings
Old Aug 1, 2013 | 09:56 AM
NonHyphenated American's Avatar
Default 81mm hub centric rings
Anyone know where I can find 81mm outer diameter rings? Biggest I can find is 78mm. I can get 5 steel wheels less than the price of 4 aluminum wheels.
Old Aug 1, 2013 | 10:39 AM
RND's Avatar
RND
SUMMIT RACING
Part Number: GOR-82-7150
However, I'd go with a 71.5 center bore wheel.
Old Aug 2, 2013 | 04:50 PM
Discount Tire's Avatar
Sponsoring Vendor
Steel wheels are not designed to accept hub centric rings. Just make sure you center the wheels during installation by following the correct 5 lug tightening pattern and you'll be fine.
Old Aug 2, 2013 | 05:41 PM
RND's Avatar
RND
Things that make you go "huh." Just another reason to go with a hub centric wheel or at least one that has a center bore within a mm or mm and a half of the factory 71.5.
Old Aug 3, 2013 | 09:15 AM
Sponsoring Vendor
Unlike alloy wheels that have proper recessed cuts in the center bore, the center bore on steel wheels are just an open stamped hole.
