? about bumpers, body lift, lighting with pics
Old Feb 4, 2011 | 08:34 AM
Borden's Avatar
Default ? about bumpers, body lift, lighting with pics
Let me start with what I have.
2008 JK Rubicon
33x12.5x15 on steelies
Teraflex leveling kit is my only lift ~1.5". Little rub disconnected now.
Smittybilt SRC Rails
Name:	iphone pics 112.jpg
Name:	iphone pics 182.jpg
After several days of research, I am torn between Rugged Ridge and Smittybilt XRC for the front and rear bumpers. In my current setup, I get a little rub flexing disconnected. I know adding these and a winch will cause some sag. Will the body lift cure this?
The deciding factor between the two fronts is the size of the Smittybilt. I think it looks good on a rig with flat fenders and 35s, but havent been able to spot it on a 33s with OEM fenders. Can somebody post/link to an image?
With the Rugged Ridge bumper, no end caps, with a winch hoop, is there space beside/behind/under the hoop to mount lights?
Any advice you can give me will be appreciated.
Thanks in advance
Old Feb 4, 2011 | 08:51 AM
JK.nick's Avatar
I recommend spacers to accommodate for the sag. As for the pic with 33s, I can't help with that at the moment (on my phone)
Now with the rugged ridge stubby with hoop, you'll be able to have lights on the hoop. All you'll need is a bracket for them. I believe quadratec sells them.
Old Feb 4, 2011 | 09:38 AM
Borden's Avatar
Thanks for the info, I would love that picture if you happen to have one. The TF level kit is a spacer kit, that is why I am looking for an alternative to offset the weight of the new bumper and winch.
Old Feb 4, 2011 | 10:19 AM
stlfan06's Avatar
Yes, the BL will give you more room in the wheel well to prevent rubbing. The average height loss due to adding a bumper/winch is around .5" (obviously depending on the weight of each) your 1-1.25" BL should give you about .5-.75" more room to stuff the tires after its all said and done.
