About that time....
Hey everyone need some advice. I am thinking of lifting the jeep and running 33. I am between TF 2.5 or OME 2 lift. I am also thinking about getting the JKS disconnects and the JKS adjustable front track bar.
Should i go with TF or OME? I need advice from people who have either!
What TF lift, BB or coil... I run the TF 2.5" BB with JKS quicker disco's and very satisfied. As for the adjustable trac, I wouldn't spend the money at this point. The axle is only going to be 1/8 - 1/4 of an inch off and will be next to unnoticeable. My ride is quite smoothe without the ADJ trac....
I ran the OME lift w/ OME shocks for over a year and really liked the ride and performance of the lift. The OME lift will yield about 3" to 3.5" of actual lift. You will want adjustable track bars. I have JKS discos and from the ones I have had and seen in the past these are the best out there.
Yea i could see that driving me nuts too just knowing. Would i need a new steering stabilizer, again i have heard mixed things about needing a new steering stabilizer. OME has a kit that comes with one, would it be worth it to even install it?
You don't need a steering stabilizer at all and for sure won't need a new one with this lift. With the OME lift you may find that your steering is a little flighty. Mine wasn't that bad, but if you are uncomfortable with it you may want a pair of lower control arms to adjust the caster.
