abs, esp, and traction control lights all on?? help
so to start off ive had 35'' tires and a 2.5" lift for about a year and a half, tonight im driving home and i make a gradual turn going about 25 and my esp light comes on, happened before no big deal, but then driving down the road the steering feels weird and it jerked to the right once, then all of a sudden my abs, esp and traction control lights come on and they stayed on even when i turned the jeep off and on, anybody have any idea
When you lift the JKs, they like to think they are going to roll over easier because of the higher center of gravity. That makes the electronic roll mitigation kick in with the esp. It's a stupid feature they came out with. When the JK is stock, it doesn't kick in until you turn at higher speeds because the center of gravity is lower. Also, make sure you're steering wheel is centered. That screws with it too. I have a esp kill switch on my JK so I don't worry about it kicking in. It also allows me to spin my tires and do donuts. There is an old write-up on it somewhere. Hope this helped.
Aside from the lights staying on you should check your track bar, sway bar links and front control arms to make sure they are not loose and torque to specs. I say this because you said your steering feels weird. Other then that have you pulled any DTC codes? Below is an old thread where it was a bad wheel sensor that caused my issue and was fixed under warranty...
Hello All,
I have had my lift over ~5mos now and never had this issue come up until these last two days. Has anyone else experience this problem? If so what was fixed. Is this a module & wheel sensor issue? Just want to get some input so I can be better informed when I try to take it to the dealer for repair..Please advise, thank you.
The easiest way would be to use a programmer such as SuperChips or Hypertech, but if you have none, Here is a link that gives you step by step instructions for retrieving the DTCs
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Diagnostic Trouble Codes DTC How to Check Them
If after you disco the battery you still have the lights, good chance you blew a wheel sensor. It's a pretty easy fix, just gotta figure out which one is toast. Good luck
Sent from my iPhone via Tapatalk.
those are the lights that are staying on on my dash, i havent checked any codes yet but i just took it up to a local mechanic i know pretty good to have him look at it before i head to the dealer, i think it might be something loose like the trackbar or whatever because i was at the bantam jeep festival and did some pretty rough trails and a big mud pit they had, maybe knocked something loose
