ABS And Traction control lights
Old Sep 4, 2017 | 10:32 PM
clos0791's Avatar
5 Year Member
Default ABS And Traction control lights
Help appreciated here. Installed a 3.5 MC lift and now I cannot get rid of these lights. I know this happens a lot after a lift. I am just looking for advise and suggestions as to where to start. My steering wheel is straight, I adjusted it as close to center as possible. Wheel sensors? I am trying to avoid the dealership. I read that auto parts stores won't help with ABS codes. Thanks for any help from those of you who dealt with this recently or in the past.
Old Sep 5, 2017 | 08:28 AM
Smudgeontheglass's Avatar
There are some auto parts stores that can read ABS codes, you just have to ask. I went to a local shop that I had history with and they read the code.
Straight wheels don't make much of a difference if your tire size isn't programmed in the system either. If it is kicking in and flashing on corners it is a programming issue.
A solid on light means that it is likely a wheel speed sensor. I had an issue this spring with my wheel speed sensor, ended up my ball joints were shot and the wobble was causing issues. Still have the stock sensor with no more ABS issues.
