ACOS installed
BEFORE
AFTER
FRONT
FRONT
REAR
Other than the obvious height difference......not much else changed. I have plenty of room to flex the 37's now and can even dial it up a little more if necessary. I will play with the rear height a little to make sure the jeep stays level when towing the trailer. All in all very happy with them and dont have to worry about them cracking and blowing out when I need them most like the plastic one can.
AFTER
FRONT
FRONT
REAR
I'm ordering mine tomorrow. I'm ordering the adjustable bumpstops because I'm not sure if they act as bumpstops too. Maybe you could shed a little light on it for me. They do also provide me with spring retainers for the rear, I need them bad! I am a little worried that they will lift me to high in respect to my lift(OME LT) and my 35's. Any suggestions on whether to pull the trigger or not?
looks real nice....i have the acos pros with the nitrogen bump stops and i am very happy with them , work great.. give you adjustably when you change things around.
It aint easy finding something you dont already have!!
figured it out...guess I was slightly impared the other day when I was trying
