Actual height of 35" KM2
Old Mar 27, 2012 | 11:08 AM
j-rod17's Avatar
Default Actual height of 35" KM2
Can anyone give me a true real world overall height of a 35" KM2. mounted on OEM 17" wheels and on the Jeep?
I know they run small but am curious as to how small under the above conditions.
Old Mar 27, 2012 | 11:14 AM
OC-JK's Avatar
I can measure mine later today for you.
Old Mar 27, 2012 | 11:16 AM
j-rod17's Avatar
great thanks
Old Mar 27, 2012 | 11:27 AM
Ryan0260's Avatar
My friends are 33.8"
Old Mar 27, 2012 | 05:06 PM
Shavehook's Avatar
Look at tire rack the specs say 34.8 on a 17x10 rim
Old Mar 27, 2012 | 05:15 PM
G520's Avatar
From: Native to Los Angeles, but migrated to Denver.
Mine are 33.5 (after about 10K miles).
Old Mar 27, 2012 | 06:10 PM
j-rod17's Avatar
your all's measurements on stock OEM 7" wide wheels?
Old Mar 27, 2012 | 06:13 PM
OC-JK's Avatar
Mine on stock rims at 28 psi is 33.75.
Old Mar 27, 2012 | 06:14 PM
wayoflife's Avatar
JK-Forum Founder
is there a reason why you need to know? if you're trying to figure things out in regards to a lift you want to install, you need to NOT look at actual measurements and just go off of what is listed on the side walls. ALL lift kits and the sizing of them are determined off of that and NOT, actual tire size.
Old Mar 27, 2012 | 07:23 PM
OutlawJK's Avatar
Mine were 34.25 on stock rims @32psi
This was the setting I used on my procal to get the speedometer
Correct to a handheld GPS
I also measured mine by marking the
Tread and rolling it one revolution
Gave that measurement to my math wiz daughter and she told me the height, revolutions per mile and all kinds of useless info.
Sent from my iPhone
