Adding limited slip or locker after re-gear?
I've just recently purchased a 2010 Unlimited Sport. Original owner replaced 3.21 gears with 5.13's when he went to 35" tires and 3.5" lift. Rear is the standard Dana 44 with open diff. I know that the gear setup requires a great deal of expertise, but how difficult is it to add a limited slip or locker? If I mark the mating gears on the ring and pinion, can I simply pull the axles and take the carrier out, replace the open with whatever I want and put the ring gear back on and make sure it all matches up the way it was? I replaced a differential on an old Mustang years ago, but remember little about it now. Any advice would be appreciated.
Only have it if you order the optional Trac-Lok on the Sport or Sahara. This one does not have it. There are two limited slip/lockers available. Trac-Lok and Tru-Lok. The Tru-Lok is the electric locker unit only available on the Rubicon. The Trac-Lok is "available" but not standard on the Sport and Sahara Dana 44 rear axle.
