adding rr xhd modular front bump w winch and stinger ??
Old May 8, 2010 | 07:29 PM
genzod's Avatar
Default adding rr xhd modular front bump w winch and stinger ??
im getting a rugged ridge modular xhd front bumper with stinger and 8000 lbs winch all by rugged ridge,i have a new 2.5 terra flex coil lift,and am running 33s,how much of a sag will i get with this if any? what can i do? i have a lot of room,but dont want it to look all sagged in the front ?? thanks for any advice
Old May 8, 2010 | 07:41 PM
wheezer's Avatar
I have the XHD bumber and Warn 9.5ti winch. When I first installed it I got about a 3/4" drop but when I installed the XHD rear bumper with tire swing a few months later it leveled out perfect!
Anyway, If you don't plan on adding a rear bumper for a while you could always add a spacer to your front coils.
Old May 8, 2010 | 07:47 PM
genzod's Avatar
so was it really noticable? did it look bad,cause it will be some time til i get the rear bumper
Old May 9, 2010 | 10:09 AM
wheezer's Avatar
Yeah, it was bad enough to convince me to buy the rear bumper sooner than I had planned. I would check out the coil spacer option.
Old May 9, 2010 | 01:14 PM
tinknocker's Avatar
Default spacer
I have same set up and I put 1" spacer in and all is good.
