Adding Switch to Factory Switch Panel
Old Dec 2, 2009 | 10:57 AM
Skippman's Avatar
Originally Posted by nangulator
I got the Daystar lower switch panel and switches, it was a easy install, fits great and I ran my own wires for lights. You have to be careful tapping in to some of the factory wiring because of the body control module.
+1 on the Daystar lower dash panel. Looks almost stock.
Old Dec 2, 2009 | 11:16 AM
CDavisJK's Avatar
There days the circuit board is cheaper than running more wires.
Old Dec 3, 2009 | 01:12 PM
djruger357's Avatar
I also used the daystar panel and rocker switches it was super easy and looks like it should from the line! i wouldnt do it any other way!
Old Dec 13, 2009 | 11:10 AM
flamingred1983's Avatar
Ok, I'm in the process of getting switches mounted in this switch bank using the information in the post I linked earlier. I had to order the round switches from the website in the heated seat write-up as I couldn't find anything that would look good and fit. As it is the switches I put in there barely fit but I got the box put back together. It's not a complicated setup but now my hazard button isn't working right. I am wondering if there is a parts list/cut sheet anywhere that I can look at to see if maybe I'm missing something that's supposed to be there. I don't know how I could have misplaced something but is wouldn't be the dumbest thing I've ever done by a long shot.
Old Mar 6, 2013 | 12:32 AM
BDAN1020's Avatar
Do you have any pics of how you ran the wiring through the back of the console, it seems pretty solid behind that panel, I'm going to be wiring my switch tonight after work, thanks
Old Jan 12, 2015 | 01:50 PM
senormac's Avatar
Did you ever solve the hazard light problem? I'm about to try this on mine, so I'd like to know if there's a delicate connection in there I need to watch out for. Thanks.
