adj. control arm length
Old May 14, 2013 | 01:45 PM
SoDak JK's Avatar
Default adj. control arm length
I just got new front adj control arms (both upper and lower) and a rear lower, does anyone know how long I would need to adjust them from eye to eye for a 3” lift to get everything lined back up, or how I would be able to get that info?
Old May 14, 2013 | 02:29 PM
SBEII's Avatar
Check the manufacture's website. Rock Krawler has the lengths for 2.5, 3.5, 5.5 on theirs.
Old May 14, 2013 | 02:54 PM
Gman*2007's Avatar
Set them with the manufactures specs then place an angle finder on top of your upper ball joints to dial the UCA's to about 4* and you'll be pretty close. You should be able to find a thread on here about front end alignments.
Old May 14, 2013 | 02:58 PM
k0260's Avatar
Since most 3" lifts vary in actual lift height, you'll need to adjust the front by setting your castor to + 4-5 degrees. For the rear, you want your drive shaft to be close to level with your pinion. TeraFlex has great instructions that apply to all adj arms.
