Adj front toe in/out alignement
I've read the write- up on front end alignment. It's all pretty straight forward and easy to do on my own a number of times. Haven't needed to mess with toe angle until recently. Project-JK.com - Jeep JK Wrangler Resource » Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment. Question is: My passenger front tire is wearing on the outer half faster. So I need to adjust my toe out? for passenger side, e.g the bottom of the tire needs to be pushed out. Do I remove passenger side link on tie rod to adjust the knuckle out further? Trying to push the front passenger side tire bottom portion out being the outer say half of tread is wearing excessively in comparison to the driver side. Hope I'm being somewhat clear to make since here....thanks for your advice
The knuckles are not adjusted independently.
Your wear issue may be from too much cross caster combined with too much toe-in.
For sure, rotate that unevenly worn tire to the back axle.
Measure caster for each side, and watch this short youtube video on toe adjustment.
http://youtu.be/K2pjCebuyDo
Sent from my iPad using Tapatalk HD
Thank you for your help. So would I adjust the driver side turn knuckle for setting toe as shown in the video? Turning it clockwise? I'm just still not quite clear. I'm working on dialing in my adj control arms, as I swapped them out from my old WP fixed length arms, both top and bottom too. I do need to recenter my axle again, it's off less than 1/4", sticking out further to drivers side. Would this have anything to do with the unusual tire wear on outer passenger side? Thanks
Taking this screen pic from his video, if you take the blue handled wrench and wrench it up, you will get toe in.
if you wrench it down, you're effectively lengthening the tie-rod bar to get the tires to toe out.
That should be correct unless Jeep engineers decided to reverse thread it....
The computer readouts for alignments don't have any meaning with regard to toe on one single side.
So, set your toe. Then, straighten your steering wheel--using the collar on the drag link.
On a solid axle vehicle, you cannot toe out only one side. The sides are connected together by the tie rod.
Caster doesn't cause tire wear but only effects handling by pulling to the side with less caster. Toe effects tire wear by feathering of the tire thread.
usually edge wear on a tire is caused by camber so i would check play in the ball joints or a bent c. Only for sure way to tell is bring it to a
alignment shop
alignment shop
alignment shop
alignment shop
