Adj. Front Trackbar Question
Old Aug 11, 2009 | 02:10 PM
mkjeep's Avatar
Originally Posted by cvjoint
Ya maybe I can come over and she can tighten up my trackbar.:thumbsup Just kidding. Any requests on new avatars?.
Haven't taken any new pics lately.
Old Aug 11, 2009 | 02:17 PM
geoffcwilson's Avatar
Back on topic, what about using loctite from the outset? Should not back off and retorquing could actually be detrimental because it would break the loctite seal......?
Old Aug 11, 2009 | 02:30 PM
mkjeep's Avatar
I don't use lock tight on mine, but if you did, just set the torque wrench 5ft lbs under and see if it clicks, that way the seal isn't broke
Old Aug 11, 2009 | 02:32 PM
mkjeep's Avatar
Better advise from cvjoint, I don't think you should locktight susp components personally, just check torque.
Old Aug 11, 2009 | 02:38 PM
crazyhorse02's Avatar
What I meant was the driver. And to see if his brain bolts are lose from not checking it anyway. Thats the first thing I check after so many miles. I guess it is mean but it is almost scary that some people put on lifts and they ask questions like this. I went to lunch today and seen a nice lifted JK with 37 on it. 4 inch lift or what ever and it had spring spacers. I took a peek under his jk to see what he had. No adjustable control arms a front track bar bracket that I grabed and was lose as hell. So I know this thing had to drive pretty shitty going down the road. I could be wrong though but I doubt it because I had to do things to mine to get it to drive straight down the road with 35's. It is just scary knowing that I am driving past these people.
I understand your point but if I came out to someone underneath my jeep.. Stand by to stand by. Pretty messed up u think u have the right to be tugging on someone (a complete stranger) elses jeep without any kind of permission.
Old Aug 11, 2009 | 03:06 PM
Hellbound13's Avatar
See now I am glad I asked cause I use loctite and lock nuts on my bolts..
Old Aug 11, 2009 | 03:10 PM
mkjeep's Avatar
If you use lock nuts, u don't use locktite.
Old Aug 11, 2009 | 03:12 PM
I know but I like overkill when it comes to the part of the jeep likely to cause dw.
Old Aug 11, 2009 | 04:21 PM
No it was not like that at all. This was a college kid and I was parked beside him of coarse his was taller with the 37's and thats all he cared about. I asked him how it drove and about his track bar I could tell one tire was sticking out more than the other side and if his trackbar was adjustable he said yes. Did not even know. Thought the bracket made it adjustable. I warned him that it was not tight and went on my way.
Well I stand corrected! I must have misunderstood. Hopefully, you enlightened him a little bit.
