Adj track bar
Old Sep 20, 2012 | 05:00 AM
AMEchambers's Avatar
Default Adj track bar
A couple quick questions for you guys...
I just ordered the rc adjustable track bar. I have the rough country 3.5" lift. I'm also running the evo drag link flip kit. My question is do I remove the track bar drop down bracket that sits next to the pitman arm? If I don't.. The track bar is too long. If I do the track bars bend is only a half inch away from the pitman arm bolt... The track bars "bend" is supposed to be upward correct? It just doesn't look right...
Old Sep 20, 2012 | 04:18 PM
Default bump....
Old Sep 20, 2012 | 04:34 PM
FallschirmJaeger's Avatar
Lifts require more adjustment than just the trackbar. Verify that all parts are correctly adjusted. Also, is it an adjustable trackbar that is meant for you level of lift?
Old Sep 20, 2012 | 04:54 PM
There is no issue with the lift. An adj track bar is highly recommended on any lift to re-center your axle. My questions are: do I keep my track bar drop bracket on or not? and does the fact that it’s so close to the pitman arm cause an issue?
Old Sep 20, 2012 | 05:17 PM
chris@offroadevolution's Avatar
Sponsoring Vendor
yes, you should not be running a drop trackbar bracket with a flip kit, it will give you bumpsteer.
Do you have drop pitman arm as well? If so, replace with the stock one
Old Sep 21, 2012 | 12:32 PM
Thanks guys! I replaced the drop pitman arm when I installed your drag link flip kit. I have been running the flip kit with the drop bracket for a month now... wondering why I was all over the place.. Removed the drop bracket, and now have the stock track bar installed and everything is allot better. Once I install the adj track bar I should be smooth sailing! Still a little conserned about how close the bend of the bar is to the pitman arm.
Old Sep 21, 2012 | 12:50 PM
Croce's Avatar
I have the same kit and trackbar too. Just checked the top of the trackbar and noticed it was slightly dented by hitting the pitman arm bolt. never noticed it before
Old Sep 24, 2012 | 10:31 AM
So is this something that I should be concerned about guys???
Old Sep 24, 2012 | 10:40 AM
Sponsoring Vendor
Cycle the suspension and check the clearance.
