adj. track bar and my ABS light?
Old Mar 24, 2012 | 03:43 PM
jeepjkgrrl's Avatar
Default adj. track bar and my ABS light?
Hi,
I did the review on the rusty's 3.25in lift, I installed the track bar and now the steering wheel is off by a 1/4 turn to the right. And my abs light goes on and it sounds like something is rubbing internally. Any ideas?
Old Mar 24, 2012 | 04:45 PM
Rich6700's Avatar
You need to adjust the track bar until the the steering wheel is straight. Most likely the ABS is activating thinking you are in a slide.
Old Mar 24, 2012 | 05:56 PM
jeepjkgrrl's Avatar
What's the best way to do that ? Should I put it on jack stands and keep turning till its straight? And I thought the tierod would cause that
Old Mar 24, 2012 | 07:17 PM
Rich6700's Avatar
Did you lift your jeep? If so did you put an adjustable track bar on it. You've got me a little confused right now.
Old Mar 24, 2012 | 07:20 PM
Rich6700's Avatar
If you put an adjustable track bar on it, adjust it while it is on the ground. Do not mess with the tie rod ends.
Old Mar 24, 2012 | 07:31 PM
jeepjkgrrl's Avatar
Sorry I should have been a little bit more precise with my explanations. I do have an adjustable track Bar, And a 3.25 rusty's lift kit. I put the trackbar on while on the ground. I find it to be easier when doing suspension parts ...less movement.
Old Mar 24, 2012 | 08:01 PM
bobbyspaghetti's Avatar
Okay I may be missing something here but I am more worried you are. Your adjustable track bar is not to centre your steering wheel. What you have it for is to centre your axle front or rear under your jeep. The track bar mounts from one end of your axle to the opposite side of your jeep's frame. The more you lift your jeep without increasing the length of your track bar the more it shifts your axle to one side. So with jeep on ground adjust your adjustable track bar to a length where the axle is centered under your jeep. Adjusting your steering wheel is something altogether different and easily found in a beyond fool proof write up in project-jk.com write up section. Hope this helps.
Old Apr 8, 2012 | 01:50 PM
jeepjkgrrl's Avatar
Oh yeah I know but it was only off by 1/4 of an inch. I centered the steering wheel by turning the drag link.
Old Apr 8, 2012 | 09:56 PM
aermotor's Avatar
Use the adj. trackbar for it's purpose, to recenter the axel.... Then (as it seems you've done) adjust the draglink to fix your steering wheel.
The ABS goes haywire if the steering wheel isn't straight because it think's you're going into a slider or under/over steering I believe.
