Adjustable arms, yes or no?
Old Dec 4, 2007 | 09:31 PM
LoganR's Avatar
Default Adjustable arms, yes or no?
I'm pretty set on getting Rusty's 3.25" lift. I've ran it on previous Jeeps and I was impressed, especially for the price. That being said... The kit has adj trackbars, coils and shocks. I'll also be adding a steering stabilizer. I want to get adjustable arms, but I'm not sure which. Let me rephrase, I plan on getting Rusty's arms as well.. but I don't know if I want the full 8 adjustable... or just the lowers. I've even thought of leaving the uppers stock until time/money permit. Any help on this would be great, thanks in advance.
Old Dec 5, 2007 | 05:27 AM
wayoflife's Avatar
JK-Forum Founder
All you really need are adjustable front uppers and lowers so that you can dial in your caster. If and when you get an aftermarket rear drive shaft, you will need to get adjustable rear uppers to set your pinion angle.
Old Dec 5, 2007 | 05:46 AM
simon's Avatar
If you were going to either get uppers or lowers, go with uppers.
I have not gotten the lowers yet, and the uppers adjusted my caster pretty damn close. Take a look at this thread: https://www.jk-forum.com/forums/show...ht=upper+lower
Old Dec 5, 2007 | 03:37 PM
LoganR's Avatar
I was under the impression that the 4drs are fine at this level. I can see where it would help, but I didn't know of any necessity. Will the pinion angle be fine without the rear arms?
Old Dec 5, 2007 | 03:44 PM
LoganR's Avatar
Thank you so much. I searched, but apparently not good enough. I will be getting the front control arms. Thanks to both of you for your quick responses.
