adjustable control arms to tighten up steering?
they work together to center your axle and adjust your caster. Uppers will do you just fine adjusting your caster.
Damn, now that just makes total sense when you think about it. I suppose the lowers are slightly easier to replace which is why I've seen most people on the forum recommend changing those.
And as FT mentioned, getting both uppers and lowers gives you the ability to move the axle forward/backward in the wheel well. (becomes more important the higher you go...)
