Adjustable Front Track Bar next purchase???
not necessarily. if your brackets came with your kit, they were probably made specifically for it and are doing a good job of recentering your axles. if not, your axles might still be a bit off and adjustable track bars would get you to where you want them to be.
I have the 3" TF and the HD trackbar and they work well together. I think now they recommend it for the 3 kit, so youll be fine with it.
I love the TF HD front track bar. It is a massisve hunk of forged steel and has been flattend near the front diff to provide more clearance. It may be the most impressive component on my lift.
It looks like you could run it on a dump truck.
It is super quiet and super stong. Very good component
Highly recommend.
Highly recommend.
Highly recommend.
Highly recommend.
I have been running a 3" lift with a rear track bar bracket and no track bar mods up front. My front axle is visibly off-center, about 1-1.5". I have a JKS front adjustable track bar ready to install. Can someone clearly state the drivability issues caused by off-center axles (front and rear), aside from aesthetics. BTW, I would describe my steering as "flighty" in the current configuration. Thanks.
