adjustable front track bar not needed?
Old Nov 25, 2008 | 02:12 PM
BlackNorthernJK's Avatar
Default adjustable front track bar not needed?
After installing my Black Diamond 3"Lift with Teraflex lower front arms, I checked all my measurements over to find my axle shifted to the passengers side about 5/8" this is after turning the adjustable front track bar down as far as possible, I just swapped out the adjustable one from the kit for the stock one and my axle is sitting centered again ??? Anyone ecounter this?
Old Nov 25, 2008 | 03:43 PM
Squad2man's Avatar
I need the adj. track bar, mine sits about 3/4" to the drivers side
Old Nov 25, 2008 | 03:57 PM
whats your setup?
Old Nov 25, 2008 | 10:16 PM
Roxster's Avatar
With the stock track bar installed you should definitely be seeing the axle pulled to the driver's side (LHD vehicles) with any lift.
Old Nov 25, 2008 | 10:26 PM
lv jk's Avatar
***erator
the track bar bracket with my kit came close but I am going to do the adj. cuz I want a 3/4" spacer to level my jk out.
Old Nov 26, 2008 | 02:40 AM
Originally Posted by S10x1000
Couldnt you just set the adjustable one to the same length as stock or maybe Im just not understanding what your saying?
Nope. The adjustable that comes with the BD 3" when spun down to it's lowest setting is still about 3/4" longer than stock...which is about how far I still had to come back to the drivers side.
I'm aware that it's most common to find the axle shift to the Drivers side the higher you lift....mine didn't, I can only guess it stayed dead center with the lift.
I'm guessing noone else has experienced this?
Old Nov 26, 2008 | 11:24 AM
I agree, but that's alright, runs true handles great so ... works for me.
Just curious if I'm the only one?
