Adjustable LCA's and still not stable?
Old Jan 18, 2010 | 08:40 AM
explorer's Avatar
Default Adjustable LCA's and still not stable?
Hi
I have a Old man emu HD kit and after having handling issues it was recommended that i get Front adjustable control arms. I did this. My castor is at 6*. My steering is dead centre but i still have to hold the steering at 2 o clock to keep it going straight (right hand drive and we drive on the left hand side of the road) My jeep feels like the front wheels "shutter" (shake ) on the road... I have ballanced my wheels again and checked my tyre pressure. All perfect. What can this be? I dont know what do do anymore?
Old Jan 18, 2010 | 08:47 AM
highoctane's Avatar
How many times have you tried adjusting the wheel? Is your Jeep pulling? Or is the wheel just not centered? I had to recenter my wheel a few times til it was perfect. What size tires do you have? I would check to make sure none of the suspension components are bent. Is the shudder happening all the time? Or just after you hit a bump?
Old Jan 18, 2010 | 08:58 AM
spinlock's Avatar
A few more questions in addition to Highoctane's?
Were your tires dynamically balanced?
When did this problem start? Right after lift kit installation? After tire rotation?
Old Jan 18, 2010 | 09:05 AM
explorer's Avatar
I had problems about 5000 miles. My Jeep pulls to the left. My steering is centred. i did this more than once. About 5 times now. The shutter is only if i hit a small bump in the road. I cant see that anything is bent. The wheels where balanced by a mashine. Not sure what dynamic is?
Old Jan 18, 2010 | 09:11 AM
explorer's Avatar
forgot to mention. Standard wheels and tyres
Old Jan 24, 2010 | 08:10 AM
explorer's Avatar
had the wheel centred again. Still pulling left. Can this be bent axle?
Old Jan 24, 2010 | 11:18 AM
zoeydad's Avatar
Check your toe.
Old Jan 24, 2010 | 07:28 PM
explorer's Avatar
Will my toe cause the pulling? Should i get the toe setting back to standard spec if i still have the standard wheels?
Old Jan 24, 2010 | 07:43 PM
ifshinxs's Avatar
Toe will not cause a pull....Period! Caster will cause a pull. A bad tire will cause a pull..Loose or worn out suspension part could cause or lead to a pull..
Your toe should be set a an 1/8 in with the stock tires.
Since this is a right hand drive. I assume that your plus 6 degrees on the left side..Right...If this is the case you probably have a bad tire..Cross rotate the front tires..If it now goes straight or pulls the opposite way you have a bad tire..
Good luck
Old Jan 24, 2010 | 08:59 PM
Bosox5's Avatar
Veteran: Coast Guard
I installed my TF front lower flexarms and set them at 23' on both sides and got 5 degrees of caster and my ride is still a little flighty but my front end is more stable over bumps and steering is much tighter.
