adjustable rear control arms
Old Oct 2, 2010 | 12:34 PM
rhino4bs@yahoo.com's Avatar
Default adjustable rear control arms
can i run them with stock drive line. i need to push my rear tires back a half inch
Old Oct 2, 2010 | 12:50 PM
wayoflife's Avatar
JK-Forum Founder
yes, you certainly can but 1/2" sounds like a lot. how much lift do you have and is it safe to assume you have a 2-door?
Old Oct 2, 2010 | 01:01 PM
Default yes 2dr
4 inch lift
Old Oct 2, 2010 | 01:08 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by rhino4bs@yahoo.com
4 inch lift
okay, with 4" of lift, i would recommend setting your lower arms to 20" eye to eye. that'll make them 3/8" longer than stock. even at this length, your coils will bow quite a bit and the passenger side may make contact with your track bar and/or, if you have a track bar relocation bracket on the axle, it may rub on it on the driver side.
