Adjustable track bar install
How hard is it to install an adjustable track bar? I have looked it up and am just trying to decide of I can do it. I have basic skills with tools and the only tool I don't have is a torque wrench.
piece of cake. this write-up has instructions on how to remove and install one in the mix
http://project-jk.com/jeep-jk-write-...ation-write-up
I agree it is easy but remember you don't really need an adjustable trackbar if your lift is below 2.5". I installed my adjustable trackbar in the front with basic tools in 1 hr. You need a hydraulic lift and preferable 2 car stands to manipulate the axle.
I also used a "come-a-long" to center the axle on the frame as well as using grade 8 9/16 x 4" bolts and washers for a tighter fit. I did have to trim the bolts to shorter length since I wanted the "shoulder" portion of the bolt to touch both sides of the frame and axle trac bar mount for that tight fit.
