Adjustable track bar...no relocation bracket
Old Oct 7, 2011 | 11:22 AM
Runewolf1973's Avatar
Default Adjustable track bar...no relocation bracket
If I have an adjustable track bar in the front, is it acceptable to run it in the stock mounting position, without a relocation bracket or aftermarket drop pitman arm? What, if any problems could the lack of these components cause? Edit to note: it's a 4.5" Trailmaster lift.
Old Oct 7, 2011 | 11:30 AM
TeraFlex's Avatar
Sponsoring Manufacturer
More info needed, how big of a lift and what flavor ?
Old Oct 7, 2011 | 11:40 AM
Sorry, I was just going to edit that... I have a 4.5" Trailmaster lift. It drives great on road, but haven't had much chance to try it offroad.
As far as I can tell, I have his lift....
http://www.trailmastersuspension.com... W/ SSV SHOCKS
I know I'll need new driveshafts and other compenents eventually, but right now just wondering about the front.
Old Oct 7, 2011 | 09:57 PM
nthinuf's Avatar
Yes. As long as it handles ok, the adj trackbar will be fine. If you find that the angles are off, causing bumpsteer or funky handling, then look into a flip kit. At that height, don't be surprised if you end up with one, along with caster correction and pinion correction for the rear driveshaft.
Old Oct 7, 2011 | 10:41 PM
Thanks for the reply! I had some funky handling when I first got the Jeep, but turned out the dealership had put 45psi in my tires.
Old Oct 8, 2011 | 04:25 AM
w squared's Avatar
Your track bar and drag link are probably pretty close to parallel, which is the most important thing. You might see somewhat improved handling by doing a track bar bracket combined with a drag link flip -the idea there would be to keep the two components parallel, but get their angle closer to horizontal.
