Adjustable Track Bars
Ok i got the RC 2.5" spring lift w/ shocks. I did not order the rear adjustable trackbar with it.
1. Why is getting the rear trackbar important? What will happen if I don't?
2. Is getting a front track bar important? Based on some reading on the forum it sounds like a front might be more important than a rear, is that right?
3. What track bar(s) should I get if they are necessary? I know JKS is popular on this forum.
Thanks again for the help guys.
I think the main reason is to get your axles centered under your rig. They have brackets that do this but can cause extra leverage on your stock mounts resulting in them getting ripped off
I would think with a 2.5 in spring lift you would want to get them, also it will give you adjustability if you decide to go higher in the future. I have a Superlift frt and a jks rear, the jks is really nice.
I would think with a 2.5 in spring lift you would want to get them, also it will give you adjustability if you decide to go higher in the future. I have a Superlift frt and a jks rear, the jks is really nice.Ok i got the RC 2.5" spring lift w/ shocks. I did not order the rear adjustable trackbar with it.
