Adjustable trackbar or bracket question?
Old Jan 19, 2009 | 12:48 PM
crutan22's Avatar
Default Adjustable trackbar or bracket question?
I am installing the RC 2.5" coil w/ shocks lift next week. Can I just get the JKS front adjustable track bar and the rear adjustable track bar and just not get any brackets at all? In other words for the rear, can I get the trackbar instead of the bracket? Any pros/cons?
Old Jan 19, 2009 | 12:50 PM
derekls's Avatar
I would go with the adj track bar.
Ive got a set of full tractions for sale right now, but Id recommend putting zerks in them before install if you went with that brand.
Old Jan 19, 2009 | 01:22 PM
JK_JOE's Avatar
Adjustable track bars only or stock track bars with brackets, not both.
I went with the JKS's front and rear.
Old Jan 19, 2009 | 03:09 PM
blazer4949's Avatar
With my 3" lift I run JKS adjustable trackbars on both front and rear.
Also have welded JKS brace on rear.
Old Jan 20, 2009 | 11:30 AM
crutan22's Avatar
I think I'm gonna go with the adjustable trackbars. Thanks for the input.
Old Jan 20, 2009 | 11:35 AM
jeepguyinMS's Avatar
I am running the same set up you are looking and and love it. I didn't want to go with the brackets because of all the stress problems I have read about them. The adjustable track bars are more expensive, but better in the long run. Also if you decide to go with a higher lift in the future you don't have to worry about it then.
Old Jan 20, 2009 | 11:56 AM
rubican!'s Avatar
jks front and rear. I saw the bracket they offer for added protection but i think tis only needed if you do crazy rock crawling
Old Jan 20, 2009 | 01:11 PM
STUPIDFACE's Avatar
Originally Posted by crutan22
Can I just get the JKS .......rear adjustable track bar and just not get any brackets at all?
i was wondering the same thing. so if you run a rear adjustable track bar, you dont need the bracket, correct?
corey d
Old Jan 20, 2009 | 01:33 PM
corey d
That is correct
