Adjusting 2012 auto shift points
Any way to do this?
Needs more of a "sport" mode where it changes *every* gear at 3 or 4K rather than:
Shifting to 2nd at 3.2k, then @2.2k to 3rd, then 1.5k to 4th (well, close to it).
If you have to give it any gas the damn thing downshifts, seems like it's always hunting for a gear, what's up w/that????
Power band is higher, right, starts about 2K (saw a HP/torque curve around here somewhere for 3.6 vs 3.8 somewhere
) and should never drop below unless your at freeway speeds etc.
Shifting manually, winding it up a bit, I get better mileage.
Using the pedal to do this creates worse mileage
Make sense?
) and should never drop below unless your at freeway speeds etc.Shifting manually, winding it up a bit, I get better mileage.
Make sense?
Help me understand this thread/reply
https://www.jk-forum.com/forums/show...-gear-question
"Okay. I'm your guy on this one. 2012 JKU, 400 miles on it. I had it built and delivered with 37s on 3:73 with the intention of having it immediately re-geared. I flashed it with the ProCal for the 37s immediately to correct the shift points on the Auto trans."
So, time for a call to "ProCal" for adjusting shift point info???
