Adjusting Caster
Unless your caster is really low (<3°), I don't think it is the cause of your death wobble. But to answer your question, definitely adjustable control arms. Upper or lower give you the same net result. As others have mentioned, most of the uppers on the market are bottomed out and can't be made any shorter. So safest bet is lowers which can be lengthened to increase your caster. You don't want the cam bolts!!! Good luck.
