advantage of adj track bars/ control arms?
A similar question has been posted about steering stablizers but I'd like to know the advantage of adj track bars and adj control arms if the JK already drives good? Is this just a worthy mod for JK's that are driving bad?
I didn't add an adj track bar with my 2 1/2 " susp lift and my JK pulls ever so slightly to the right. Could this be because my axle isn't centered? Would an adj. track bar fix this?
Thanks
Thanks
Thanks
Thanks
My teraflex 3" made my rear axle shift way over to where the driver tire was against the control arm. I was surprised how much it was off. JKS front and rear got it back. The jeep tracks like an arrow.
I centered my steering wheel whenever I did my lift. Everything that I've read and been told about alignments is that it is a waste of time on JK's. As I said, it is a VERY SLIGHT pull. I'm just picky, my wife says she can't even tell it's pulling.
If you have an adj track bar on a BB lift, do you need to install the supplied Track bar bracket that some kits come with?
And if you have an adj track bar, when do you really need to install the track bar bracket? 3" or more inches of lift?
no, the brackets are in place of an adjustable track bar.
I was shocked at hoe much better this thing drives after I installed the adjustable track bar. My axle was almost a full half inch out of center.
Seems to have cured my wobble problem too.
