Advice for onboard air
Old Aug 16, 2010 | 01:10 PM
Red Rock Sam's Avatar
Default Advice for onboard air
Putting in a viair hardmount compressor. I was planning on putting a quick connect up front in the passenger side frame accessable from the wheelwell. I am planning to run a connector in the rear as well, but no spot is jumping out at me there. I was considering the License plate holder where it extends beyond the drivers side body, facing forward. This is on a basically stock Rubicon unlimited. Any advice or suggestions?
Old Aug 16, 2010 | 02:38 PM
Alec's Avatar
I just put a quick connect in the rear of mine. I drilled through the trunk floor on the driver side close to the rear and on the outside of the tub structural member (if you look up from underneath). I mounted the coupler to the inside of the rear bumper on the side, behind and above the tire. Works great!
I'll have some pics soon.
