advice for rear upper adj control arms install
Old Sep 24, 2008 | 07:54 AM
roguejk's Avatar
Default advice for rear upper adj control arms install
Ok, so I ordered my rear upper adjusable control arms to line up the pinion with my new rear driveshaft , anything I should know about the install of the arms as far as a bolt that has to be cut or anything? Or is it just put the frame on jackstands and a lift under pumpkin. Just asking for tips and or tricks.
Also putting in rear adjust. Track bar and the woods evap relocation kit.
Any additional info would be great
Thanx guys
Old Sep 24, 2008 | 08:31 AM
greggradwohl's Avatar
Thanx guys
You will want two jacks. One to lift the axle, the other to adjust the pinion angle. Put a tiny bit of pressure on the second (angle) jack before disconnecting your stock control arms. I think the writeup of the full traction ultimate 3 inch has a picture of this.
